Home Forums Products Stompboxes Help – Trying to mimic a step-filter flanging effect Reply To: Help – Trying to mimic a step-filter flanging effect
#147134
brock wrote:
Two things to note:  Those direct assignments are global, and will affect every preset / algorithm differently.  And second, there’s a limit to how much continuous data the H9 will take, before it starts freaking out.  Dropped information, display goes crazy, etc.  It’s a lot to process simultaneously.
Re the global settings.
Yes they are global settings on the H9 but on my ES5 I can determine whether to send that data on a per patch basis.
For example.   I can load patch 143 and it will send:
– a midi PC to change to the patch on the H9
– Sync the H9 midi clock to the ES5 BPM setting
– And then send whatever CC messages I want, continuous or singular.
Re Freak out.
Yeah, I have found if I am sending continuous cc midi other midi can often be dropped.   (ie.  I need to do the PC before I start doing any CC events)
Ill give those modfilters presets a go.
I have been messing with the resonator algorithm with constantly changing the resonance and all 4 notes.  It also seems to achieve a result that is getting relatively close, but certainly not perfect….  yet
