Home › Forums › Products › Stompboxes › Space Reverb: Tap Tempo in Spring Mode › Reply To: Space Reverb: Tap Tempo in Spring Mode
        September 11, 2017 at 2:28 am
        #147138
I also wanted to use tap tempo just to effect tremelo speed, leaving reverb decay alone. It seems to me that more flexibility in this area would be great. Say if you were to hold down the tap button on the control app for a second, and then select which parameters are controlled by tempo and which are standard values?
