Home › Forums › Products › Stompboxes › Assigning more than 3 functions on H9 › Reply To: Assigning more than 3 functions on H9
September 13, 2017 at 8:58 am
#147147
Thanks for your help, i’m very encouraged there is a solution to this! I attach my current settings which are : Active FS – PS on/off; Barn 3 FS’s set to increment and decrement PS, and I dont use the tap at all. So your second recomendation (”you dont need tap tempo.. then I would use the right side barn for down, the right side H9 for up, and the left barn for Flex.”) would be perfect set up for me. However the way I see it is there are only three FS assignments available so I dont see how to map which to which.
