Home Forums Products Stompboxes Assigning more than 3 functions on H9 Reply To: Assigning more than 3 functions on H9
#147149
camn
    Sure, this is easy.
    First, on the H9…. just hold down the right hand button.
    That will flip it from tap tempo to increment (without activating). If you want that one to decrement (without activating), then hit the hot-knob switch.
    side note-If you are dying for it to increment/decrement AND activate, the H9 wont do it. Maybe someday, but right now no.
    Then, in H9 control, you assign your aux switches.
    step 1- Pedal–>General settings–>Use Exp pedal, Aux sw, or both–> assign AUX SWITCH
    step 2- Pedal–>Aux Switch Mappings—>Decrement (or increment if you flipped it above)–> set to footswitch 2 (I THINK that is the right hand switch. . experiment if not!)
    step 3 – Pedal–>Aux Switch Mappings—>Performance Switch–> foot switch 1 (I think)
    And that is it!
    Another side note–> foot switch 3 is if you hit both the Barn buttons at once. Toggle Tuner, maybe?
