Home Forums Products Stompboxes Using the Tech 21 MidiMouse with H9 Reply To: Using the Tech 21 MidiMouse with H9
#147175
Seems that if the USB is plugged in then the Midimouse isn’t recognized.  Once I unplug the USB it works fine.  In the H9 Control program you have the option under ‘Settings’ to select a Midi device, however it only recognizes what is available thru the USB.
Any thoughts.
