Home Forums Products Plug-Ins How to use sidechain on Equivocate with Cubase 8.5? Reply To: How to use sidechain on Equivocate with Cubase 8.5?
#147217
I got it to work in Cubase 9. and it onlty took me an hour or two.
  • I created 3 quatro (not stereo) groups
  • 1 for the main signal to be processed.
  • 1 for the sidechain
  • 1 for EQuivocate
  • On the inserts on the first two groups I added Steinbergs MixConvert.
  • In MixConvert I routed the main signal group to stereo (should have worked without this, but it didn’t – which is partly why it took so long).
  • I routed the output to No Bus.
  • In the sidechain group I routed MixConvert to Stereo (Ls Rs).
  • in the EQuivocate group I inserted EQuivocate.
  • I routed the output to Stereo.
  • Then I used send from the channels I needed to process to the first group.
  • And then I sent the channels for sidechange to the second group.
  • I routed their output to Stereo.
  • Then I could open EQuivocate in the last group and match the signals.
I hope the sidechain button comes soon, because this was a pain in the… yes you know 😉
-Henrik J. Larsen
