Home › Forums › Products › Stompboxes › Use external MIDI device to scroll through H9 presets and auto-load? › Reply To: Use external MIDI device to scroll through H9 presets and auto-load?
September 25, 2017 at 4:49 am
#147220
yes of course.
You decide which CC you want. You set it up in the H9 control
You can also use PC to call certain presets directly. Also setup in H9 control.
The helix should do all that easily… be warned though.. there have been some troubles using the helix for the ‘performance switch’. Use an aux switch for that of you can/care/want
