Home › Forums › Products › Stompboxes › Eventide SPACE – Can I go from preset #1 to #50, #60… fast? › Reply To: Eventide SPACE – Can I go from preset #1 to #50, #60… fast?
September 29, 2017 at 2:40 pm
#147285
brock wrote:
The fastest method is MIDI Program Changes (usually sent from an external MIDI pedal or foot controller). As an alternative, you can move the order of the presets around to match the sequence in your stage set. Then Bank Up using the onboard footswitch, or Bank Down using an auxiliary switch.
Hi Brock,
I see that this is an old thread, but would you be able to recommend a particular option for the first solution you suggested?
Thanks in advance.
