Home Forums Products Stompboxes Space pedal problem, not receiving input signal Reply To: Space pedal problem, not receiving input signal
#147341
    It sounds like you have a sophisticated setup, which may have its own problems. In our experience, this is usually the case.
    To rule out hardware issues, please try each unit on its own, with dsp bypass, and guitar in, and out to amp, using input one and output one only.
