Home › Forums › Products › Stompboxes › Fractal Audio EV-2 expression pedal with H9 › Reply To: Fractal Audio EV-2 expression pedal with H9
#147354
Dr.Jackle
    nickrose wrote:
    A 100K pot is on the high side and will give the results you report. A 25K or less pot is best.
    You could have a techie friend change the pot for you.
    I could change the pot, but I also need to use the pedal with the Axe-Fx for which it was designed for. The Boss FV500L is a little bit more linear but on the opposite side. I guess there’s no option but to buy the Ernie Ball Vp Jr. if I want better sweep.
