Home Forums Products Stompboxes How to connect H9 to my mixer / interface? Reply To: How to connect H9 to my mixer / interface?
#147379
gkellum wrote:
I don’t understand how you’ve currently connected the H9 to your mixer, but it sounds like you have it attached the main outputs of your mixer?
Have you tried connecting it to one of your mixer’s aux sends? Then you can send particular channels to the H9. Hooking things up this way will only work though with certain kinds of effects like delays and reverbs. Using the H9 as an aux send will cause phase cancellation problems with other kinds of effects like modulation.
Hi gkellum
right now I’ve got it connected this way; H9 input 1/2 going to my mixers AUX sends 1/2. H9 outputs 1/2 are going to my mixer’s AUX RTN 1 – L and R. Everything I do after that is a guess. I connected a cable from H9 ouput 2 to mixer’s AUX RTN 2 RIGHT and got a signal from my stereo synth in stereo.. but when I  gently added more value on the AUX SEND 1 MONI.. then I got a high whistling noise simililar to guitar feedback.
I think there’s possibly a simple solution to my problem, I just don’t see it.
Thank you for your reply.
Fred
