Home Forums Products Stompboxes H9 Midi question – bypass, activate, preset + Question on ISW and OSW Reply To: H9 Midi question – bypass, activate, preset + Question on ISW and OSW
#147426
    >> Byp and Act seem to work as expected except ACT doesnt load the preset selected by PR+/-.
    It's not supposed to. It just makes the current preset active – the opposite of bypass.
    Questions:
    1. Can you tell me exactly how I am to send the CC messages?
    • Like any other CC.
    1. Do I send a 127 followed by 0 or just a 127?
    • Like any other CC.- a single value between 0 and 127.
    ISW and OSW:
    1. Are they expecting values from 0-127?
    1. What is the difference between ISW and OSW?
    • As described in the manual, ISW is Input Swell, and OSW is Output Swell. The difference is the point at which the level change is applied. An input swell will affect the level of the instrument, while an output swell will affect the overall output level of the effect.
    1. When a preset is loaded what is the default setting?  i.e.  if I have a pedal sending a range from 0-1217 what do I have to end at to be back to original?
    • I'll get back to you – it changed with different softwares.
