Home › Forums › Products › Stompboxes › H9 Midi question – bypass, activate, preset + Question on ISW and OSW › Reply To: H9 Midi question – bypass, activate, preset + Question on ISW and OSW
#147427
Thanks – I know I CAN send any cc value, but the documentation does not describe what the pedal is expecting.  I am lookng for what I SHOULD send for each of the Control Destinations.  Its not clear which are binary and which are continous for example.
For example, through experimentation I have discovered that sending 0 to BYP actually ACTIVATES the pedal where sending 127 BYPASSES.  The inverse is true for ACT.  This makes them functionally the same as each other and the TOG destination no?
FIRST Question: if I select a preset by sending a CC 127 to either PR+ or PR- it will blink on the pedal display but not be loaded as expected.  If I send a 127 to ACT the pedal will activate but the preset will not load.  What am I supposed to do to load a preset selected with PR+/-?
SECOND question:  For the ISW control destination, what is the pedal expecting?  Am I merely turning on/off ISW with a 127 or 0,  to be controlled by an EXP pedal, or is the ISW destination the swell controller and take continuos messages 0-127 to control volume?
