Home Forums Products Stompboxes Where can I find a PDF of the Mixing Link Application Handbook? Reply To: Where can I find a PDF of the Mixing Link Application Handbook?
#147472
Berme
    Given To Fly wrote:
    I have no idea if this will help, but I agreed with your statement about the diagram being unintuitive. I added numbers marking the signal path and order of events. The cables have little arrows on them which make sense once you realize they are little arrows and not just part of the cable image.
    Thank you, that helped a lot. Now I see it clearer.
    One more question, though. If using a cab simulator pedal, and not using a mic with a real cab, could I optionally insert the cable coming from the cab sim pedal into the Instrument In of the Mixing Link? I mean instead of the Mic/Line In shown in the diagram. This way I could match the outputs better, I think.
    Also, could I use the Mixing Link DI/Line Out for sending the final signal to one of my Scarlett 18i8 XLR Combo inputs instead of the To FX output as shown in the diagram?
    Thank you so much for your help and patience.
