Home › Forums › Products › Rackmount › GTR4000, freezing, blank screen/ fragmented carachters.Please help……. › Reply To: GTR4000, freezing, blank screen/ fragmented carachters.Please help…….
after a few attempts, i put the gtr4000 out of the 4 U flightcase it was sharin wit the Electrix Repeater,and it worked fine. I tried again,worked fine.Both the dispaly an the whol unit.Eve th initial check up procedure showed noting wrong
So i took the Repeater off the 4U flight case,and put only the Gtr4000 back in, just on the top, leavin the 2U rack space below it free.
Played for 40 minutes, loading different presests, no poblems whatsoever.
So either it was overheatin or the Repeater-that has a separate and not onboard power transformer- was affectin the Eventide some way, even when it was not turned on.
I’ll do few more tests during th week, thanks for your imput just the same.
