Home › Forums › Products › Plug-Ins › Octavox › Reply To: Octavox
#147521
tlongabaugh
    Hi-
    If you've run the installer, you should be able to open it in any AAX/AU/VST compatible host.
    If you are on Windows and using VST, you should make sure that you have set up your DAW to include the following VST path:
    c:Program FilesCommon FilesSteinbergVST2Eventide if your DAW is 64-bit
    or
    c:Program Files (x86)Common FilesSteinbergVST2Eventide if your DAW is 32-bit
