Home › Forums › Products › Stompboxes › Little probleme with FC300 and timefactor › Reply To: Little probleme with FC300 and timefactor
#147651
    You probably want to talk to Mr.Roland if you have issues with your FC-300.
    That said, I took a brief look at his UM, and I note that the switches can be defined as either MOMENTARY or LATCH. The TF usually wants a MOMENTARY, but the FC-300 defaults to LATCH. This is probably your problem.
