Reply To: Time Factor Midi problem…help
Home Forums Products Stompboxes Time Factor Midi problem…help Reply To: Time Factor Midi problem…help
#147690
riksplace
Tried different midi cables. I have several. They all worked with the other midi pedal.
I have several presets set on the Mastermind PBC. When I go to different presets I just need it to tell the TF to cahnge to the proper delay preset. Very simple. Not trying to get it to do anything complicated at all.
Just nothing happens at all on the TF when I change presets on the PBC. The other midi pedal will change. I have now taken the other midi pedal out of the picture so the TF is connected directly to the PBC. All on midi channel 1 (although I have tried other midi channels just in case it would be something simple like that not working). Been over everything on the TF and just can’t figure out why it won’t accept the Pgrogram Change command from the the PBC.
