Home › Forums › Products › Stompboxes › Getting my first analog synth – what to try with H9? › Reply To: Getting my first analog synth – what to try with H9?
#147709
Bodde
    Thanks again Brock. Finally got it working using the TB-03 as a master. Problem was that I had the USB hooked up to use the H9 control on my computer. I always connect it to USB when I use it at home. But the midi sync doesn’t work when hooked up to USB. Not sure why that is? But I think that was the problem.
    I think you can still use the H9 control and still have tempo sync when you connect it to bluetooth though.
    Too bad it doesn’t work on the Minibrute. I also tried it on my other synth (MFB Dominion 1) and that also doesn’t work. The midi implementation says System Realtime Clock T/R: x  Does this means it doesn’t tranmit or receive midi clock? Although I have read somewhere that it can be synced to a DAWs tempo. Just got this synth so I don’t know it all yet.
