Home › Forums › Products › Plug-Ins › Fission – does it support automation, MIDI mapping / learning? › Reply To: Fission – does it support automation, MIDI mapping / learning?
#147727
gkellum
    Well, these features are normally handled by the DAW that you're using Fission in.
    In all DAWs that I know you add an automation lane to a track you want to add automation to, and you select one of the plugins parameters to control in that automation lane.  You can do that with Fission.
    Similarly with MID mapping / learning, in a DAW like Live you put Live in learn mode and move the parameter you want to control in the plugin, and Live maps that parameter to your controller.
    If you'd like you could download the free 30 day trial for Fission and try it out in your DAW and make sure that everything is going to work as you'd like it to.
