Home Forums Products Stompboxes Algorithm for volume and wah Reply To: Algorithm for volume and wah
#147796
gkellum
    Jmarlwin wrote:
    Thank you for the advice. Which one should I assign to my EXP pedal if I want it as volume pedal? Input or output?
    Likely the output gain…  Assigning the expression pedal to the input gain can be interesting if you want to cut the signal going into your H9 for example but want the delay or reverb trails to continue, but that's a pretty niche use case…  People more commonly want to control the volume of the entire mixed signal.  That's what a volume pedal does in any case…
