Home › Forums › Products › Stompboxes › Time Factor Bypass/Activate with Musicom Lab Preset Help › Reply To: Time Factor Bypass/Activate with Musicom Lab Preset Help
December 5, 2017 at 2:03 am
#147804
Immersed wrote:
Hi, I’m in need of help putting my Time Factor in Bypass when switching presets on my Musicom Lab EFX LE midi loop switcher. I can get the Time Factor to activate when I hit preset 4 of the Musicom but when I go to presets 1-3 it stays active and I need it to be bypassed. I am using midi channel 5 and CC5 to activate the TF thru midi. How do I bypass it for the the other presets? Thanks!
Ok, how are you going to presets 1 – 3? Are you using MIDI program change messages? If so, if you save a preset as bypassed, it will load bypassed.
