Home Forums Products Stompboxes Time Factor Bypass/Activate with Musicom Lab Preset Help Reply To: Time Factor Bypass/Activate with Musicom Lab Preset Help
#147809
    Immersed wrote:
    nickrose wrote:
    Mr. K means that if you save the preset when the pedal is Bypassed (not Active, left red light off), it will load Bypassed from a MIDI Program Change.
    I just tried that and now it stays bypassed for preset 4 which I need active.
    I think we have a misunderstanding here.
    If the preset is bypassed when you save it, it will load bypassed (from MIDI)
    If it is active, it will load active.
    Not much more I can say.
    Except that – if it loads bypassed, you saved it bypassed. Make it active, then save it again.
