Home Forums Products Stompboxes Time Factor Bypass/Activate with Musicom Lab Preset Help Reply To: Time Factor Bypass/Activate with Musicom Lab Preset Help
#147810
nickrose wrote:
Immersed wrote:
nickrose wrote:
Mr. K means that if you save the preset when the pedal is Bypassed (not Active, left red light off), it will load Bypassed from a MIDI Program Change.
I just tried that and now it stays bypassed for preset 4 which I need active.
I think we have a misunderstanding here.
If the preset is bypassed when you save it, it will load bypassed (from MIDI)
If it is active, it will load active.
Not much more I can say.
Except that – if it loads bypassed, you saved it bypassed. Make it active, then save it again.
Maybe it has to do with the Musicom Lab then. I don’t know, I’m lost. If I bypass the pedal manually and then hit my 1-3 presets on the Musicom it stays off, if I hit preset 4 on the Musicom it’s active, if I got back to the other presets 1-3 on the Musicom it stays active. I fee like I need a control change # to bypass the time factor and save it to my presets on the Musicom.
