Home › Forums › Products › Plug-Ins › UltraChannel AU Plugin not working in Garageband › Reply To: UltraChannel AU Plugin not working in Garageband
December 5, 2017 at 6:05 pm
#147817
TLongabaugh wrote:
What is the exact error message you get?
Does GarageBand crash after you try to instantiate UltraChannel, or does it freeze, or something else?
Hi
there is a first warning error msg when loading GB but GB : “the AU ultrachanne could not be load and should be updatid. please contact your dealer”.
it’s also impossible to use the plugin when existing in monitor windows and also impossible to load the plugin the same as first warning error msg
please note the named AU “ultrachanne” but not “ultrachannel”
no freeze or somethying else : GB is OK.
