Home Forums Products Stompboxes CC to enable/disable MIDI clock input? Reply To: CC to enable/disable MIDI clock input?
#147887
nickrose wrote:
Hi Edo
Ask me again in the New Year, and I can give you a Sysex to disable MIDIclock in.
Our thinking was that if you were using MIDIclock, this would be your tempo master, and you would not try to override it.
A situtation where you had tap tempo fighting received MIDIclock did not seem attractive. We thought you should pick one or the other.
Thanks Nick! Yes I understand that scenario, in which case I’d be happy for a persistent MIDI clock to win over the manual tap.
My clock generator is not persistent and I’m making of use of that nature to give me flexibility to tap in a new tempo quickly.
Will ask you again in the new year!
Cheers.
