Home › Forums › Products › Stompboxes › H9 core download question › Reply To: H9 core download question
#147901
gkellum
    isadore wrote:
    I tried pressing the preset switch twice and nothing happened.I tried it with both the active switch and off. Also, the algoritnm I downloaded was "Hall" will it show up as that?
    Well, if you press the Preset switch twice on the H9 it should switch from showing the preset name to the algorithm name and then you can use the wheel to scroll through the list of presets.
    But in any case why don't you just use the app to save some Hall presets onto your H9?
