Home Forums Products Stompboxes H9 Harpeggiator not working with Tempo On Reply To: H9 Harpeggiator not working with Tempo On
#147912
DGillespie
    SteveBowman wrote:
    I'm having this same problem. But can't blame the MIDI clock because it is receiving clock — from a TimeFactor! The PF does receive tempo changes correctly and has consistently since I set it up. But Harpeggiator only seems to work correctly with Tempo Off. I do need it to sync to the clock because everything else in my setup, including looper, is synced.
    (To be perfectly accurate, the clock signal is originating in a ModFactor, then passed thru the TimeFactor to the PitchFactor; and then out to a Nemesis Delay and then looper.)
    Steve
    Hi Steve,
    Is the TimeFactor set to send midi clock out, and is the TF synced to midiclock?  Can you make it work by just connecting the MF to the PF?
    Dan
