Reply To: Time Factor Expression Pedal
Home Forums Products Stompboxes Time Factor Expression Pedal Reply To: Time Factor Expression Pedal
#148003
sumpe13
So – based on the info – the Timefactor JACK is actually TRS – does that mean that the Boss EV-30 should work just fine with it??
I had a Line 6 Expression pedal (TS / mono) which worked well –  so I am a bit confused, does the Timefactor accepts both Mono and TRS cables?
