Home Forums Products Stompboxes Connect Midi Device to Eventide Device – Bluetooth doesnt work Reply To: Connect Midi Device to Eventide Device – Bluetooth doesnt work
#148043
gkellum wrote:
It’s likely that the H9 is ignoring MIDI clock sent that way.  Trying to send MIDI clock over Bluetooth will cause problems with your Bluetooth connection to your H9.  MIDI clock can generate hundreds of messages a second, which will interfere with the app trying to communicate with the H9.  Plus, even if that were not the case, there would be so much jitter added to the MIDI clock sent this way that the tempo value would be unstable and fairly unuseable.
thank you – so its clear: midi over bluetooth makes no sense 🙂 only midi clock sending wired will make sense, isn’t it?
