Reply To: H9 Control for Android is now in private beta
Home Forums Products Stompboxes H9 Control for Android is now in private beta Reply To: H9 Control for Android is now in private beta
#148071
bohan
Rongok wrote:
On my tab s 10.5 the algorithm screen is a bit off. The pedal name text is slightly behind the algorithm graphic. On the pedal screen the top row of knobs is halfway off the screen. They still work fine. Both these issues only appear to be in landscape mode.
Hi, thank you for your feedback! Can you tell me a bit more detail for us to fix this issue on your device? What happens when you turn your tab from portrait to landscape? Based on what you described, I assume when you turned your device to the landscape view, H9 Control didn’t recognize and respond to it. Because the landscape view of the Algorithm screen should look same to Mac or PC.
