Home Forums Products Rackmount independent recording for Sample 1 and Sample 2 H8000FW Preset 5224 Reply To: independent recording for Sample 1 and Sample 2 H8000FW Preset 5224
#148072
    On looking at it, it appears that using the softkeys to record or play operates both samplers, so it records or plays all (4) channels.
    If you use the inputs 1 and 3 to perform an audio triggered record or play, you can drive the samplers independently.
    The inputs 1 and 3 refer to the inputs to the preset, after the routing. These will be DSPA_IN1 and DSPA_IN3.
    The INFO page correctly describes the operation.
    Note that the trigger EQ allows more control over the audio triggering, for example you could set it up so that a bass drum triggered the record or play.
