Home › Forums › Products › Stompboxes › How to turn ON/OFF 2 eventide stompboxes connected by MIDI (timefactor as master and space as a slave)?? › Reply To: How to turn ON/OFF 2 eventide stompboxes connected by MIDI (timefactor as master and space as a slave)??
January 15, 2018 at 10:31 am
#148111
nickrose wrote:
4_cuerdas wrote:
Is it possible to use one of the button-switches of my ext switch pedal to bypass both units?
If it suits your other needs, you could connect the AUX switch(es) in parallel, either individually or with a TRS Y-lead. Make sure this does not create a ground loop.
Ok. Thanks for your reply Nick.
Cheers.
