Reply To: Eventide Space clipping
Home Forums Products Stompboxes Eventide Space clipping Reply To: Eventide Space clipping
#148113
As the thread you mention says, this can be caused a a problem with the delay memory chips. Unfortunately we don't have an automatic test to detect this, but it seems to occur only when running certain reverbs.
It could also be caused by a faulty power supply, or cabling issues.
I would suggest that you check cabling and make sure you are using the supplied power supply.
If you find nothing, you will probably have to send the unit in: support@eventide.com
