Home Forums Products Stompboxes How to turn ON/OFF 2 eventide stompboxes connected by MIDI (timefactor as master and space as a slave)?? Reply To: How to turn ON/OFF 2 eventide stompboxes connected by MIDI (timefactor as master and space as a slave)??
#148157
4_cuerdas
    bohan wrote:
    You can also use an aux switch to turn on/off the first stompbox (set the mapping of this switch to Bypass) and use a MIDI cable to connect these two stompboxes. Set a CC number for this aux switch (TIP, RING, or T+R, depends on which switch you want to use) in the first stompbox's XMT CC setting. And assign this CC number to "Toggle" in the second stompbox's RCV.CTL (assign received MIDI CC to pedal functions) setting accordingly. By doing so, you don't have to use a MIDI pedalboard.
    Perfect!. I have already a Digitech f3sx and I can assign one of the switches to do the bypass. Thanks a lot for your answer!
    Cheers!
