Home Forums Products Stompboxes H9 Wish List Reply To: H9 Wish List
#148230
Adamixoye
    bohan wrote:
    Adamixoye wrote:
    I can’t remember if I’ve mentioned this before, but I really wish there were a chromatic (non-key based) version of the quadravox algorithm, e.g., for multiple root-5th-octave organ sounds.
    Sounds like a good idea. I think I also once wanted to play like this. Can’t assure whether or when will it be updated though…
    Currently, I would recommend you:
    1. still use Quadravox, set the MODE to Major. As long as you don’t hit major 7th notes in the key of the KEY knob, you can always get perfect 5th notes to make this organ-like sound.
    2. Try H910/H949 algorithm. Set one pitch to 1.5 and another to 2.0. Turn delays to 0 (or very small) and give both voices a bit feedback (add a bit more on the 2.0 pitch voice). You should be able to get this kind of organ sound.
    Hope it can help.
    Thanks,
    I tried some of these and they were okay; I think the real issue is that I would like to be above to do something like octave below, 5th up, octave up.  The other suggestion of Pitchfuzz worked for this.  And you’re right that you can sort of fake it with the Quadravox algo.
