Home › Forums › Products › Stompboxes › H9 and Modfactor: MIDI footswitch to select a certain preset? › Reply To: H9 and Modfactor: MIDI footswitch to select a certain preset?
January 26, 2018 at 8:32 pm
#148234
The Eventide stomps want a suitable MIDI Program Change to load a preset. It looks as if the FC6 will do this.
I suggest that you read and understand the MIDI Map section in the UM to be sure you load the programs you want.
You should speak to Mr.Korg if you need help setting up his pedalboard.
