Home › Forums › Products › Stompboxes › Powerfactor 2 and the GigRig G2 › Reply To: Powerfactor 2 and the GigRig G2
#148269
camn
    It looks to me like you would be under-specced with that combo… although it certainly might WORK, and be totally fine.
    Alternate suggestions:
    The new Truetone CS-6 should DEFINATELY fit under a Templeboard…. if it has enough juice for your setup.
    I (and others) use a CS-7 with my H9, and it is flawless. . . and would PROBABLY be doable on a templboard….but maybe not.
    e.g: https://www.thegearpage.net/board/index.php?threads/temple-board-w-truetone-cs-7-power-supply.1893910/
    For reference: Heights:
    Powerfactor: 1.75″
    Cs-6: 1.22″
    CS-7: 2″
