Home Forums Products Plug-Ins Problem with EQuvocate Plugin Reply To: Problem with EQuvocate Plugin
#148343
DGillespie
    Hello, Tom is correct that your issue should be partially solved by upgrading to version 1.0.7, which is the current release. There is a bug in some GPUs available on the Windows platform where not all OpenGL function calls exist. Version 1.0.7 of EQuivocate detects this condition and renders the plug-in UI in software rather than on the GPU. Unfortunately, this means that we won’t be able to render the individual band meters when OpenGL is off.
    You may also be able to solve this problem by using your graphics driver, but unfortunately many GPUs with this error do not have available updates.
