Home Forums Products Stompboxes Powered-up TimeFactor not remembering Aux Switch settings since update Reply To: Powered-up TimeFactor not remembering Aux Switch settings since update
#148370
    There are two reasons why the TF may not save settings:
    1) Most likely – you have a faulty or non-Eventide power supply.
    2) Less likely – a hardware fault. We had one batch of units long ago where they installed the wrong component in the powerdown circuit, which can cause this.
    A test of the power down circuit:
    1) Power up.
    2) Select a different preset.
    3) Power cycle.
    4) If the new preset is displayed, all is OK. If the original preset is displayed, the powerdown circuit is bad.
