Home Forums Products Plug-Ins UltraChannel AU Plugin not working in Garageband Reply To: UltraChannel AU Plugin not working in Garageband
#148372
TLongabaugh wrote:
Hi dran_sy, this should solve the problem:
Make sure GarageBand is closed. Go to your ~/Library/Caches folder (this can be found by clicking “Go” in the Finder menu bar while holding down the option key), and delete the com.apple.audiounits.cache file located there. Then, open iLok Manager and make sure the UltraChannel License is activated on either your iLok dongle or computer. Launch GarageBand, and you should be good to go! GarageBand will need to rescan your AudioUnits folder, but this should solve the problem.
Let me know if that doesn’t solve the problem.
Tom Longabaugh
Eventide
Hi, i’m getting the exact same problem as the OP after installing apple’s nighmare new operating system on my mac. I can now no longer open garageband which i use on a daily basis.
I deleted the cache file as per your instructions but i don’t know what ilok is or how to use it so i’m unable to fix this.
I’ve attached a picture of what i’m stuck on when i try to open garageband.
Please help.
