Home Forums Products Stompboxes Timefactor: Long Tap Tempo question Reply To: Timefactor: Long Tap Tempo question
#148392
bohan
    asopaque wrote:
    Is there any way to have the Tap Tempo screen stay active so I can enter a 'long' tap?
    Hi, if you turn off Tempo mode, the maximum delay time 3000 ms; if you turn on Tempo mode, the maximum delay time is still 3000 ms. Please remember that in Tempo mode you're not tapping delay time, you are tapping BPM. So if you set the tempo to 30 BPM, a delay value of 1/8 is 1s, a delay value of 1/4 is 2s, and a delay value of 1/4 dot will be 3s.
