Home Forums Products Stompboxes Opto/Bias Tremolo / Phaser Question Reply To: Opto/Bias Tremolo / Phaser Question
#148401
bohan
    brickbriscoe wrote:
    If I can find a tutorial on linking my two h9 via midi for my set list using one to change both units as needed I'm all set!
    If you just want to use one H9 to control another H9 when you switch presets, it's easy. Just use a MIDI cable to connect your H9s. Go to your first H9's setting menu by pressing and holding HOTKNOB and right footswitch, and set as follows: Settings->MIDI->PGM.XMT->turn it to ON, then you are all set. If you want to transmit more messages and control more parameters/expression, this thread may be helpful: https://www.eventideaudio.com/community/forum/stompboxes/controlling-pitchfactor-and-modfactor-midi
