Opto/Bias Tremolo / Phaser Question
Home › Forums › Products › Stompboxes › Opto/Bias Tremolo / Phaser Question
    • #107985
      microwerx
        I have a question about using the Tremolo on my Mod Factor. I want to recreate a Fendery opto style tremolo and a Vox bias style tremolo. My question is, which LFO will recreate the appropriate waveforms for these effects? I've just been using one of the presets that sounds good, but when I try to create my own, it doesn't sound quite right. For example, when I try to recreate a Fender type tremolo, I expect it to be kind of square wave like, but the square wave is on/off/on/off…but not quite like the vintage circuit…so it sounds like I'm using a Boss slicer type effect. Any advice?
        My second question is, does anyone have some good Small Stone style patches they've come up with for their Mod Factors?
        Any help and advice would be immensely appreciated.
      • #122404
        achaput
          For the style of Tremolo you're looking for I would start with Factory Preset 7:1, Tumbleweed Trem. It uses a SINE wave.
        • #148404
          brickbriscoe
            so more or less set up preset list on both and they will coincide if I do the first thing?
            • #148405
              bohan
                Yes. For instance, if you switch the first H9 to preset 10, the second H9 will also go to preset 10.
              • #152419
                brickbriscoe
                  so if i want it to switch the second one to “bypassed” is there something i need to do?  when i’m switiching the sercond one comes in armed as well
                  thanks
              • #148396
                brickbriscoe
                  you answered my question before I even asked!  thanks.  now if i can find a tutuorial on linking my two h9 via midi for my set list using one to change both units as needed i’m all set!
                  thaks
                  Brick
                  achaput wrote:
                  For the style of Tremolo you’re looking for I would start with Factory Preset 7:1, Tumbleweed Trem. It uses a SINE wave.
                • #148401
                  bohan
                    brickbriscoe wrote:
                    If I can find a tutorial on linking my two h9 via midi for my set list using one to change both units as needed I'm all set!
                    If you just want to use one H9 to control another H9 when you switch presets, it's easy. Just use a MIDI cable to connect your H9s. Go to your first H9's setting menu by pressing and holding HOTKNOB and right footswitch, and set as follows: Settings->MIDI->PGM.XMT->turn it to ON, then you are all set. If you want to transmit more messages and control more parameters/expression, this thread may be helpful: https://www.eventideaudio.com/community/forum/stompboxes/controlling-pitchfactor-and-modfactor-midi
                  • #152424
                    bohan
                      brickbriscoe wrote:
                      so if i want it to switch the second one to "bypassed" is there something i need to do?  when i'm switiching the sercond one comes in armed as well
                      Every preset in H9 can be saved with "Bypassed" or "Activated". If you bypass this preset and save it again. When you switch to this preset it should be bypassed.
