Home Forums Products Stompboxes Volume Boost for Solos Reply To: Volume Boost for Solos
#148406
mustafaicil
    bohan wrote:
    mustafaicil wrote:
    Is there anyway to use an aux switch to boost volume for solos? It is cumbersome to create a separate preset for different output volume versions of the same effect. It would be great to boost the volume a few db with the press of an aux switch button.
    Currently, you can only use expression pedal or MIDI to control the output level. This feature might be available in the future through a firmware update but we don't know when that will be.
    Thanks. Hopefully it comes as a feature for the aux switches soon.
