Home Forums Products Stompboxes Expression pedal via MIDI controller setup help please Reply To: Expression pedal via MIDI controller setup help please
#148455
    jphoyt wrote:
    I went into the MIDI settings and set the expression pedal value to MIDI CC 1. When I select a preset, do I have to set something else up to use the pedal?
    You have to be sure that whatever MIDI pedal you are using is sending on CC1. You also have to make sure that its channel matches that set on the H9 (or, to makethings easier, set the H9 RCV.CH to OMNI).
