Home › Forums › Products › Stompboxes › Expression pedal via MIDI controller setup help please › Reply To: Expression pedal via MIDI controller setup help please
Well, one thing to be aware of is that some manufacturers number MIDI messages starting at 0 and others starting at 1. So, it could be that you're dealing with an off by one error.
If that isn't the issue, if I were you, I'd connect the Switch Doctor to a computer to double check what values it is sending. On Mac I'd use MIDI Monitor, and on Windows I'd use MIDI Ox. They're both free apps…
Well, the actual MIDI mesaages sent on the Switch Doctor are 0-127 even though they’re displayed as 1-128.
Does that mean that if the expression value on the H9 is set at MIDI CC2 it needs to be set as MIDI CC2 on the Switch Doctor?
