Home Forums Products Stompboxes Timefactor – change delay type without changing preset name? Reply To: Timefactor – change delay type without changing preset name?
#148470
bohan
    When you change the delay type you are changing to another algorithm. Even though the knobs stay at same positions, the knobs and the signal processing behind them have been changed. For example, the same knob in different algorithms can be FILTER, MOD, XFADE, or SATURATION.
    Although you can't do that on the unit, I would recommend you connect your TimeFactor to a computer and use H9 Control edit software. It will be easier for you to switch and compare those algorithms by creating a preset list of different algorithms with the same set of parameters.
