Home Forums Products Stompboxes DIY Aux Switch Reply To: DIY Aux Switch
#148621
camn
    ok its easy as pie.
    You need AT LEAST one of these:
    https://lovemyswitches.com/dpdt-momentary-foot-switch-solder-lug/
    But you could use that switch for ALL THREE if you wanted.  But you need at least one. FOr the other two you can use this:
    https://lovemyswitches.com/spst-momentary-foot-switch-normally-open-soft-touch/
    Then you wire them up… here is a quick skectch… but it is totally easy:
