DIY Aux Switch
Home Forums Products Stompboxes DIY Aux Switch
Viewing 8 reply threads
    • #114620
      tura750
      Hi everyone! I’m trying to do an external Aux Switch for my timefactor but It doesn’t work. I have a stereo jack connector, 3 normally open switches, 2 1N4001 diodes and a trs cable. I followed the digitech fs300 schematics but when I plugin in the switches and try to assign each of them the display shows “T+R” for a while (while I Press the switch) and then goes back to the previous setting (RNG).
      Any suggestion?
    • #148510
      Please just buy an FS-300 and save yourself and us a lot of trouble.
      There may be reasons why you can't do this that are beyond my ken. In this case, I would suggest that your RNG switch is probably shorted or, (apologies), maybe miswired.
    • #148526
      camn
      ha ha.
      I can maybe help, I have made a dozen ‘DIY’ switches.
      I dont use diodes.. but a DPDT for the 3rd swtich (its a $0.50 well spent, imo),,, but the diodes should work fine, if you dont have one.
      That said- one question- do you get nominal readings with a multimeter?
    • #148557
      Herr Mosa
      As I want to mount the aux-switches on my pedalboard without additional housing:
      @camn
      are you willing to post the schematic voodoo for me?!?
    • #148589
      camn
      I am traveling now.. but I can make one soon.
      But as mentioned.. if you dont already have parts- I would use two singles and a double throw switch for this.
      DO you have parts already, or no?
      And what are you mounting in? Wood? Metal?
    • #148614
      Herr Mosa
      No I don’t have the Parts yet – I’ll mount it on a pedaltrain. As I’m electronically skilled I’ll be aware of shorts and do isolate the components.
      I would really appreciate your schematic
    • #148621
      camn
      ok its easy as pie.
      You need AT LEAST one of these:
      https://lovemyswitches.com/dpdt-momentary-foot-switch-solder-lug/
      But you could use that switch for ALL THREE if you wanted.  But you need at least one. FOr the other two you can use this:
      https://lovemyswitches.com/spst-momentary-foot-switch-normally-open-soft-touch/
      Then you wire them up… here is a quick skectch… but it is totally easy:
    • #148623
      Herr Mosa
      That’s great – thanks a lot for the information @camn!
      May I conclude: the DPDT simply closes Tip+Ring simultaneously to GND, just that simple?!
      As I’m from Germany, I will search for this momentary switches somewhere ’round here. But now it’s clear
    • #148624
      camn
      yes exacly so- the DPDT handles two separate circuits with one press… which is the only special thing about the third switch.
      There is probably a reason people use the diodes instead.. but considering the DP only costs 4 cents more.. I cant see why we should!
